Update Audi RMC K15028
Dieses Thema im Forum "Audi A1 Anleitungen, Tipps & Tricks" wurde erstellt von Libertyx82, 15.11.2016.
  1. lscangus
    lscangus Mitglied
    [QUOTE = "C'Booster, post: 234332, member: 2406"] Did you try to start the update? [/ QUOTE]
    Thanks for your reply. I have updated and updated. But i have no idea why i dont have SDS function now ( it said SDS not installed ), but you can see the associated files are updated OK in the images below. May be i have to reactivate it in VCDS?
    [​IMG] [​IMG] [​IMG] [​IMG]
  2. JuzzA1
    JuzzA1 Audi A1 Süchtling
    Als ZIP Datei kann er das allerdings nicht lesen .. das war beim Bluetooth Update anders ..
    Gesendet von iPhone mit Tapatalk Pro
  3. Libertyx82
    Libertyx82 Audi A1 Guru
    The SDS Function is only available if your car have the Speech dialog system. (Special equipment)
  4. lscangus
    lscangus Mitglied
    Hello. Before the upgrade, I do have that function.
  5. Libertyx82
    After you have Updated to Version 13464 did you have also Updated to Version 15028?
  6. lscangus
    lscangus Mitglied
    Not yet. Should I proceed?
  7. Libertyx82
    I would test it. It could be that the Files for the SDS are not be updated by Version 13464
  8. lscangus
    lscangus Mitglied
    Thank you for your message. Will try later this week. Car is in paint shop
  9. JuzzA1
    Was hat das Update jetzt gebracht, wo sind die erkennbaren Unterschiede, als ich damals mein Fahrzeuge bekommen habe hatte das Radio noch via Bluetooth die Alben Cover angezeigt und jetzt ist das schon lange weg ... Vorteile das updates sind nun welsche.
  10. lscangus
    lscangus Mitglied
    [QUOTE = "Libertyx82, post: 235522, member: 3991"] I would test it. [/ QUOTE] [/ QUOTE] [SITE]
    I remembered the SDS was updated. Took a long time. you can see the images i took during update.
